Using the Landing Page
After you sign in to Avid Content Core, the system displays the Landing Page that gives you fast access to trending assets, recently added assets, and more. Avid's expectation is that the Landing Page can provide you with access to the media assets that you need through either an intuitive search, or directly through suggested content that is based on recent trends — eliminating the need to conduct more advanced searches.
The following illustration and table provide more information about each of these sections.
Section
Description
1
Search Bar
This "natural language search" bar allows you to complete semantic searches. Semantic searches focus on the meaning of your search term, and not just the actual text that you enter into the search field.
For more information, see Using Search and the Search App.
2
Item Counter
As you select assets in the Exploration Panels, this counter displays the total number of items currently selected. You can select up to 100 assets on the Landing Page at any one time.
The Deselect All button to the right of the counter allows you to clear your selection.
3
Action Buttons
Provides access to the following features:
  • Add to My Collections
    Adds any asset(s) that you select in the Exploration Panels to My Collections. For details, see Using My Collections.
  • Send to Web Editor
    Sends any asset(s) that you select in the Exploration Panel to the Project Bin of your desired Web Editor project. For details, see Using the Web Editor App.
4
Fast Bar
Provides access to other apps and tools within your Avid Content Core system.
For more information, see Exploring the Fast Bar.
5
Exploration Panels
Filling the majority of the Landing Page, ACC provides you with fast access to assets and commonly used features through the following panels:
  • Trending
  • Recently Added
  • Favorite Searches
  • My Collections
  • My Day
  • Recently Modified
For additional information on these areas, see Using the Exploration Panels.
6
User Menu
Displays your ACC user name and enables access to additional features and settings.
For more information, see Exploring the User Menu.
7
Expand / Collapse Player
Opens or Closes the Player panel. For more information, see Using the Player Monitor and Tabs.
8
Layout Settings
Allows you to customize the look of the Landing Page. For more information, see Customizing the Landing Page.
9
Scroll bar
Use the vertical scroll bar to view additional areas of the user interface.
10
Navigation Buttons
Some Exploration Panels include buttons to the left and right of the panel that allow you to move through the list of assets. These controls appear in Card View only.
11
Alternate Navigation
The dots below the panel indicate the number of pages with additional content. You can click any of the dots to move to another page of results.
The Layout Settings allow you to customize the user interface to better meet your individual needs and preferences. Settings are saved in the cloud on a per-user basis, so that the user interface looks the same — no matter where you access it.
The following table provides more information about each setting.
Name
Description
Layout
Select how you want to display assets in Trending Items, Recently Added, and similar areas.
  • Card View
  • Grid View
For more information, see Understanding Layout Views.
Card Size
If you select Card View, this allows you to determine the how much on-screen space is used to display the cards within each exploration panel. Options include Small (S), Medium (M), and Large (L).
Edit Mode
Allows you to show or hide individual panels on the Landing Page. For details, see Using Edit Mode.
To use the Layout Settings:
  1. Click the Layout Settings button in the upper-right corner of the Landing Page.
    The Layout Settings selection menu is displayed.
  2. Enable or disable the settings as desired.
    With the exception of Edit Mode, settings are applied to the Landing Page as soon as you select them.
  3. Click anywhere outside of the menu to close it.
The Trending, Recently Added, and Recently Modified panels all have a similar look and controls. This section details how to use Card and Grid views.
With the exception of the assets in the My Collections panel, you cannot drag assets from the Landing Page to another area of the user interface.
Using Card View
Card view displays assets as a series of tiles. If you use this display mode, navigation controls appear to the left and right of each panel.
The following illustration and table explain the how to use the tiles in Card view.
Name
Description
1
Selection Box
Click anywhere in the card to select the asset. You can enable the check box(es) for one or more cards, and then do any of the following:
  • Click the Add to My Collections button at the top of the Landing Page, or click the Add to My Collections button on a card.
    Adds all selected items to the My Collections app.
  • Press Ctrl+C on the keyboard to copy the assets to the My Collections app.
  • Click the Send to Web Editor button at the top of the Landing Page.
    Sends supported asset types to the Project Bin of a Web Editor project. You cannot send multiple sequences to the Web Editor in the same action. For details, see Using the Web Editor App.
If you double-click on any card in the Trending, Recently Added, or Recently Modified panels, ACC opens that asset in the default app that is associated with that asset type.
2
Asset Type and Name
Displays the name of the asset and its associated icon.
For more information on asset iconography, see Asset Icons.
3
Info Button
Click this button to display a short list of asset metadata.
4
Adds this asset to the My Collections app.
Using Grid View
Grid view displays assets and metadata in a series of rows and columns, similar to the Search app. If you use this display mode, horizontal and vertical navigation scroll bars might appear below or to the right of each panel (depending on number of assets and screen size).
Similar to Card view, the far left column displays a check box that you can click to select the asset. If you hover your cursor over any row, an Add to My Collections button appears to the far right.
Using Edit Mode
Each of the Landing Page panels are widgets that can be displayed or hidden based on your preferences. You can also reorder the widgets to move your favorite features to the top of the page.
When you enter Edit Mode, the app draws a dotted outline around each of the panels (widgets) and a series of buttons appear in the upper-right corner of each panel. Additionally, the app displays a Disabled Widgets panel to the far right. The following illustration shows these controls.
Pictured: Sizing menu (left), Position controls (mid), Hide button (right)
To hide widgets:
  2. Click the Edit Mode button.
  3. Click the Disable (X) button to hide any widget.
    You can repeat this step as many times as desired, but you must leave at least one widget enabled. As you hide widgets, they appear in the Disabled Widgets panel on the right.
  4. When you are done customizing the widgets, click the Layout Settings button again and then click the Edit button to exit this mode.
To re-enable a hidden widget:
  1. After entering Edit Mode, do one of the following:
    • Click the green plus on any widget that appears in the Disabled Widgets panel on the right.
    • Drag and drop the widget to your desired position.
    The widget is moved back to its previous position and it maintains any sizing changes that you might have made to it before hiding the widget.
  2. When you are done customizing the widgets, click the Layout Settings button again and click the Edit button to exit this mode.
To alter the size of the widget:
    • Click the widget sizing menu and select one of the options (25%, 50%, 75%, or 100%)
    • Drag the left or right side of the widget left or right to increase the size of the widget.
      As you hover over the widget, blue dots appear to the left and right to help identify each side. As you resize the widget, the page displays gray virtual blocks to indicate snap points. If you release the cursor when a block is displayed, the widget snaps to that size.
    If you change the size of two or more widgets, they might appear next to each other. The total space available to consecutive widgets must not exceed 100%. For example, a widget sized at 50% could fit next to two additional widgets that are each sized at 25%. However, you could not combine a 50% and 75% sized widget on the same row because that would exceed the 100% maximum.
  2. When you are done customizing the widgets, click the Layout Settings button again and then click the Edit button to exit this mode.
To reorder the widgets:
  1. After entering Edit Mode, do any of the following:
    • Click the Up or Down arrows to move the panel up or down by one position.
      The panel swaps position with the one above or below it.
    • Use the grab bar to vertically drag and drop the panel to a new position.
    • Drag and drop the panel (vertically or horizontally) to a new position.
