Using the Exploration Panels
The Landing Page provides access to the following panels:
Trending
This is a list of assets that are being used by other users in your team, department, or organization.
Recently Added
Displays a list of assets for which proxy media has recently been made available. The panel sorts this content according to the Created metadata field (newest to oldest).
Recently added (and Recently Modified) assets take the time-zone into account when displaying this list of assets. For example if you create an asset in New Your at 5pm, and another in London at 5pm, the two assets are not likely to be listed next to each other. Although both were created at 5pm, there is actually a 5 hour difference in their creation time.
My Day
This panel displays up to 100 tasks that might be assigned to you through the Tasks app. The panel uses the "My Day" filter to display only those tasks that are incomplete, assigned to you, and for which the Due Date is either today or earlier. Tasks can be displayed in either Grid view, or Board view — depending on your Landing Page Layout settings. Each tile includes the name of the task, as well as information about that task. For additional details on each of these fields, see Using the Tasks App.
You can double-click any of the tiles in this section to open the task in the appropriate app (Tasks or Review and Approval for example).
Favorite Searches
If you create a favorite in the Search app, that search appears in this panel. You can click any favorite to automatically switch to the Search app and run the search. For details, see Creating and Using Search Favorites.
Favorite searches are listed in a grid pattern (two rows, multiple columns) with the most recent search appearing at the top left, and oldest at the bottom right. This panel can include up to 100 favorite searches.
My Collections
This is an alternate visualization of the My Collections app. Anything that you add to this space is added to the same collection in the My Collections floating window. The reverse is also true. For details, see Using My Collections.
Recently Modified
The panel displays assets whose metadata has been recently changed. For example if someone adds a comment to a source MediaCentral asset, changes the name of an asset through an on-prem process, or makes an edit to a Web Editor sequence, the asset could appear in this panel — sorted according to the Modified metadata field (newest to oldest).
Exploration Panel Controls
The exploration panels include the following controls.
Name |
Description |
1 |
Select All / Deselect All |
Allows you to select or deselect all assets in this panel (even if they are not currently displayed on screen). If you click this button, the check box for each individual card is also selected. If necessary, you can select or deselect individual cards using the check boxes on each card. If you select all and then deselect a single asset, the top-level check box is deselected. n Does not apply or appear next to the Favorite Searches, My Collections, and My Day panels. |
2 |
Expand / Collapse |
Click the chevron to the left of the panel to collapse it (if shown) or reveal it (if collapsed). This action hides or reveals all of the cards within that panel. |
3 |
Name |
The name of the panel. |
4 |
Asset Count |
The total number of assets available in this panel. Each panel can include up to 50 assets. |
5 |
Open In Search |
Displayed to the right of the Recently Added and Recently Modified panels only, this button opens the Search app in Advanced mode and displays a list of all assets by the following:
Results are sorted by these columns, even if you have hidden these values through the Search app's Display Options menu. If you had already used the Search app in this user session, your previous search and results are cleared when you click the Open in Search button. |
