Web Editor App Shortcuts
Keyboard shortcuts available when working with the Web Editor app are listed in the following tables. For more information, see Using the Web Editor App. To customize the keyboard shortcuts, see Configuring the User Settings.
Navigation
Shortcut
Description
Focus
Arrow Down (or apostrophe)
Source monitor: Jump to the Mark In point, Mark Out point, or last frame of the asset
Record monitor or Sequence Timeline: Jump to the next transition, Mark In, or Mark Out point on the timeline (any track)
Source, Record, or Sequence Timeline
Arrow Up (or semicolon)
Source monitor: Jump to the previous Mark In point, Mark Out point, or first frame of the asset
Record monitor or Sequence Timeline: Jump to the previous transition, Mark In, or Mark Out point on the timeline (any track)
Shift+Up Arrow
Shift+Down Arrow
Moves to the beginning of the asset or timeline
Moves to the end of the asset or timeline
Source, Record, or Timeline
Left Arrow
Shift+Left Arrow
Move one frame back
Move one second back
Right Arrow
Shift+Right Arrow
Move one frame forward
Move one second forward
Shift + I
Go to Mark In point
Shift + O
Go to Mark Out point
+ (plus)
Zoom in on the timeline
Record monitor, Sequence Timeline
Shift+/ (Forward slash)
Using the position indicator bar as a reference, increases to maximum zoom
- (minus)
Zoom out on the timeline
Playback
Shortcut
Description
Focus
Space
Toggle Play / Pause
J
Rewind
For additional information, see Using the J-K-L Keys for Playback.
K
Stop
L
Forward
Hold J
Rewind half speed
Hold L
Forward half speed
/ (Forward slash)
With In and Out Marks added, plays In to Out
Source monitor
/ (Forward slash)
Using the position indicator bar as a reference, play current segment from start of segment
Audio
Shortcut
Description
Focus
R
Starts or stops a voice-over recording
Shift+Z
Z
Expand / collapse all audio tracks
Expand / collapse the audio for a selected segment in your sequence.
M
Mute or unmute
Mute selected audio track (only impacts the playback of audio within the Editor app, does not affect audio in the published file)
Ctrl+S or Cmd+S
Solo track
Only the selected track will be audible, all others will be muted (only impacts the playback of audio within the Editor app, does not affect audio in the published file)
Record, or Timeline
Alt+A
Enable / disable Audio Scrubbing mode
Sequence Timeline
Editing
Shortcut
Description
Focus
I
Mark In
Win: Alt+I
macOS: Option+I
Alt+click or Option+click the Mark In button
Remove Mark In
O
Mark Out
Win: Alt+O
macOS: Option+O
Alt+click or Option+click the Mark Out button
Remove Mark Out
E or Enter
Add clip to the end of the timeline
Y
Add 10 seconds of filler to the Main track at the position indicator bar
B
Blade separates segment into two sections
W
Insert clip at playhead
Q
Overwrite area that has already been identified by Mark In and Out points
Ctrl+C or Cmd+C
Copies selected sections of the sequence
Sequence Timeline
Ctrl+C or Cmd+V
Pastes selected sections of the sequence
Sequence Timeline
Delete or Backspace
Delete selected clip, transition effect, or graphic
Sequence Timeline
Ctrl+Z or Cmd+Z
Undo last action
Anywhere
Ctrl+Shift+Z
Cmd+Shift+Z
Redo last action
Anywhere
F
Using the position indicator bar as a reference, loads the asset into the Source monitor
Sequence Timeline
D
Opens the Transition Effect window
For details, see Adding Transition Effects.
Shift+G
Opens the Graphics Designer
For details, see Adding Titles and Graphics.
T
Mark the frame to be used as thumbnail
Arrow Left
Arrow Right
Trim one frame left
Trim one frame right
Sequence Timeline (Trim Mode)
Ctrl+Arrow Left
Cmd+Arrow Left
Trim one second left
Ctrl+Arrow Right
Cmd+Arrow Right
Trim one second right
A
Deletes the portion of the segment to the left of the position bar.
S
Delete the portion of the segment to the right of the position bar.
Shift+A
Dual roller trim forward
Shift+S
Dual roller trim backwards
Alt (Win) or Option (Mac) + mouse drag
Trims slower for finer detail
