Using the Namespace Editor App (Early Access)
The Namespace Editor app allows system administrators to view, create, and modify asset attributes displayed in Avid Content Core (ACC). You can also select which attributes are searchable, filterable, and sortable in the system. This gives you control over how attributes are used when searching, filtering, and sorting assets.
The Namespace Editor app also includes the Taxonomies tab, which allows you to create taxonomies and assign them to custom attributes for asset classification and metadata organization. This helps standardize data entry, improve search accuracy, and ensure consistent tagging across systems.
To access the Namespace Editor app:
Sign in to Avid Content Core (ACC) with an account that is associated with the Workflow Administrator role.
Click the User Menu in the upper right corner of the ACC user interface and select Admin Mode.
In the Admin mode Fast Bar, click the Namespace Editor button.
The Namespace Editor app opens.
The left navigation section of the Namespace Editor app is an expandable and collapsible area that displays the available namespaces. It allows you to select a namespace to view, create, and modify attributes. In the example above, you can choose the namespace to which you want to apply your settings. Each namespace contains its own attribute settings, where you can define the attributes available for searching, filtering, and sorting. Selecting a namespace opens the Attributes Table.
This section covers the following topics:
The Attributes Table
The Attributes Table contains a list of predefined and customized attributes. Predefined attributes are read-only, system-defined attributes that are provided by default, while custom attributes are attributes that can be created and modified to allow you to define your own attributes for an asset.
Each attribute contains details such as ID, Title, Data Type, and Category. It also contains information on whether an attribute is searchable or sortable in the system. The following table describes each detail.
Attribute Detail |
Description |
(Attribute) ID |
The unique identifier of the attribute. |
(Attribute) Title |
The user-facing label for the attribute. Unlike the attribute ID, the display name is shown when viewing an asset's attributes. The English display name serves as the fallback label for all supported languages and is synchronized with the attribute title. Depending on the user's language settings, a localized label may be displayed instead. |
Data Type |
This indicates the classification of the attribute. It can be any of the following data types:
Multi-Value |
This specifies whether the attribute can store multiple values. If enabled, the attribute accepts a list of values (an array) instead of a single value. n This option can be enabled during the creation of a custom attribute. Once saved, it cannot be changed. |
Full-Text |
This makes the attribute searchable through full-text search operations. n This option can be enabled during the creation of a custom attribute. Once saved, it cannot be changed. |
Filterable |
When checked, this allows users to filter search results based on the Attribute Title. |
Sortable |
When checked, this allows search results or lists to be ordered according to the attribute's value. |
Taxonomy |
This displays which taxonomy is linked to the attribute. For more details, see Taxonomies. |
Category |
This indicates whether the attribute is a Predefined (system specified) or Custom attribute. |
Working with Attributes
The top navigation area of the Attributes Table allows you to search for, view, and create an attribute. Each column is resizable and can be arranged through drag-and-drop according to your preference. You can also use the Search Filter to quickly find a specific attribute, view attribute details by selecting an attribute, or create a new custom attribute by clicking the Add Attribute button.
To search for an attribute:
Select the namespace for which you want to view the available attributes. The Attributes Table opens.
In the Search Filter, do one of the following:
Type in the Custom Attribute ID of the attribute you want to view.
Type in the Attribute Title of the attribute you want to view.
Type in the Attribute Data Type. This will display all the attributes associated with the specified data type.
Type in the Taxonomy. This will display all attributes associated with the specified taxonomy.
To view attributes:
Do one of the following:
Select the Predefined button if you want to view only the predefined or system attributes.
Select the Custom button if you want to view only the custom attributes that have already been created.
n By default, the All button is selected, which displays all the available attributes in the selected namespace.
To view the details of a specific attribute:
The Attributes table opens.
Find the attribute by using the Search Filter.
Manually locate the attribute by selecting either the Predefined or Custom attribute buttons.
Click the attribute to view the details.
The Attribute Details window opens.
The Attribute Details window displays information about the selected attribute, including a list of its available localized languages. For more details, please see Localization.
To create a custom attribute:
At the top navigation area of the Attributes Table, select the Add Attribute (+) button.
Enter the required values for the attribute.
Click Add to create the attribute.
When creating a custom attribute, note the following:
A Custom Attribute ID must only contain letters, numbers, and underscores.
A Custom Attribute ID can only have a maximum of 5 underscores.
A Custom Attribute ID length is limited to 40 characters.
A Custom Attribute ID must not begin with a number.
A Custom Attribute ID must not end with an underscore.
Once the attribute has been created, you can no longer modify its ID and Data Type. You can only modify the Title and the Filter and Sort options of that custom attribute.
To modify a custom attribute:
Click on the attribute that you want to modify.
Edit the details of the attribute. You can only edit the attribute's Title and its filterability and sortability.
Click Save to apply your changes.
To delete a custom attribute:
Click on the attribute that you want to remove from the namespace.
Click the Delete button.
A warning window appears, informing you that deleting the attribute from the namespace may take a few hours. Click Delete to confirm your selection.
