Taxonomies
A taxonomy is a hierarchical classification structure used to organize and categorize assets in a structured manner. It provides a predefined set of values for classifying assets into categories and subcategories. You can assign a taxonomy to a custom attribute, enabling assets to be classified during creation using a controlled set of values.
To access the Taxonomies table:
  1. Sign in to Avid Content Core (ACC) with an account that is associated with the Workflow Administrator role.
  2. Click the User Menu in the upper right corner of the ACC user interface and select Admin Mode.
  3. In the Admin mode Fast Bar, click the Namespace Editor button.
    The Namespace Editor app opens.
  4. Click the Taxonomies tab.
    The Taxonomies table opens.
Similar to the Attributes Table, the Taxonomies Table provides an overview of all available predefined and custom taxonomies. You can choose which category to view by clicking the Predefined or Custom buttons, and add localized values for each available language.
Taxonomies Table
g You can also open the Taxonomies Table by double-clicking an attribute of the taxonomy data type that has a taxonomy assigned to it.
Each taxonomy also contains details such as the Taxonomy ID, Title, Origin, and Category. The following table describes each detail.
Detail
Description
(Taxonomy) ID
The unique identifier of the taxonomy.
(Taxonomy) Title
The display name of the taxonomy.
Origin
This indicates the namespace where the taxonomy is saved.
Category
This indicates whether the taxonomy is a Predefined (system specified) or Custom taxonomy.
To create a taxonomy:
  1. Open the Taxonomies table.
  2. Click the Add Taxonomy (+) button.
    The Taxonomy Details window opens.
  3. Enter an ID for the taxonomy.
    (Option) Add a localized language for the taxonomy.
  4. Click Add to save and apply your changes.
    c Once a taxonomy is created, the taxonomy ID cannot be edited.
To view a taxonomy's details:
  2. Do one of the following:
    • Find the taxonomy by using the Search Filter.
    • Manually locate the taxonomy by selecting either the Predefined or Custom buttons.
  3. Click the taxonomy to view the details.
To delete a taxonomy:
  1. Click the taxonomy that you want to delete to open the Attributes Table.
  2. Click the Delete button.
    A confirmation dialog appears.
  3. Click Delete to confirm the action.
Assigning Taxonomies
Assigning a taxonomy to an attribute allows the attribute to use a controlled set of predefined values. This ensures consistent metadata entry, improves searchability, and supports standardized classification across the namespace.
To assign a taxonomy to an attribute:
  1. In the Attributes Table, create an attribute by selecting the Add Attribute (+) button.
  2. Enter the Attribute ID and Title.
  3. Select Taxonomy in the Data Type field.
  4. Select the taxonomy you want to assign to the attribute.
    (Option) Enter the other details required.
  5. Click Add to create the attribute with the assigned taxonomy.
When assigning a taxonomy to an attribute, note the following:
  • The data type of the attribute must be Taxonomy to allow a taxonomy to be assigned to the attribute.
  • A taxonomy can be assigned to an attribute only during attribute creation. If no taxonomy is assigned, the attribute's data type automatically changes from Taxonomy to String when the attribute is saved.
  • Once a taxonomy has been assigned to an attribute, the link cannot be modified.
  • Double-clicking an attribute opens the taxonomy assigned to that attribute.
Taxonomy Entries
A taxonomy entry represents an individual node within a taxonomy hierarchy. Entries are used to organize and classify information in a structured manner, allowing related items to be grouped under broader categories. Each entry can have parent and child relationships, forming a hierarchical structure that ranges from top-level entries to more specific descendant entries.
The top-level entry serves as the root of the hierarchy, while child entries provide progressively more detailed classifications. By organizing entries into a hierarchy, administrators can create logical relationships between categories and improve the consistency and discoverability of asset metadata.
The following example illustrates a taxonomy hierarchy:
The Location taxonomy contains categories such as Asia, Europe, and North America. Each category contains more specific taxonomy entries. This hierarchical structure helps organize information into meaningful groups, making it easier to classify and find related assets.
To add entries to a taxonomy:
  1. Open the Taxonomies tab.
    • Manually locate the taxonomy by selecting the Custom button.
  3. Do one of the following:
    • Select the taxonomy and click the Entries button.
    • Double click the taxonomy.
    The Taxonomy Entries window opens.
  4. Create a top-level entry by doing one of the following:
    • Select the taxonomy and click the Add Entry (+) button.
    • Right click on the taxonomy and select Add Entry.
    The Entry Details window opens.
  5. Enter the required details.
  6. Click Add to save the entry.
  7. (Option) You can create multiple top-level entries and add multiple child entries. You must select an existing entry before you can create a child entry below it.
To help maintain taxonomy performance and manageability, the Taxonomy service limits taxonomy hierarchies to a maximum depth of 10 levels and maximum of 30,000 entries. Hierarchy depth is determined by the number of levels from the top-level taxonomy entry to the deepest descendant entry. Note the following:
  • The top-level entry is Level 1.
  • Each child entry increases the depth by one level.
  • The deepest entry in the hierarchy determines the overall taxonomy depth.
In the example above, the taxonomy depth is 3, because the deepest entry (Tokyo) is 3 levels below the root of the hierarchy (Location).
To delete entries from a taxonomy:
  1. Locate the entry from the taxonomy that you want to delete.
    Select the entry and click Delete in the Entry Details window.
    Right click on the entry and select Delete Entry.
  3. To confirm the deletion, select Delete in the confirmation dialog.
    n When you delete an entry, all of its child entries are also deleted.
