Viewing Notifications
Notifications alert you to system events that relate to your Avid Content Core user account. For example, users of the Review and Approval app receive a notification when the approval status of their Review and Approval task has changed (Requested, Rejected, or other); users that have been assigned to a regular team task in the Tasks app receive a notification when the task is created, in progress, or completed.
You can customize the types of notifications that are displayed. If you don’t want to receive notifications as message banners, you can mute them by feature or application. For more information, see Configuring the Notification Settings.
Message Banner
When an action generates a new notification, a message banner appears in the upper-right corner of the user interface that provides a synopsis of the notification, as shown in the following example.
You can identify the action that generated the notification by its icon.
Icon |
Meaning |
Review and Approval App notifications are sent in the following cases:
Notifications are sent to the Creator and Assignee of the task – if they are not changing the stage by themselves. |
Tasks App notification are sent when the state of a regular user task of access type "Team" has changed (not started, in progress, and completed) Notifications are sent to the Creator and Assignee of the task – if they are not changing the state by themselves. |
ACC Automation notifications are sent in the following cases:
Notifications are sent to the users configured in the rule or notify command. |
Depending on the timing of the notifications, one or more might appear on-screen simultaneously. In this case the notifications are arranged vertically with the most recent notification appearing at the top.
Each message remains on screen for a few seconds and then disappears automatically. When the notification appears, you can either click the message banner to read it, click the X in the upper-right corner of the message to clear it, or do nothing to allow it to close on its own.
If more than one notification of the same type appears, the notifications are grouped and displayed as notification stack. A collapsed stack shows the most recent notification and an unread-counter. Clicking on a notification stack expands the group without launching an application for the notification or marking anything read. To close the notification stack, you can either hover your cursor over message banner and click the X that is then shown in the upper-right corner, or do nothing to allow it to close on its own.
Notifications App
When notifications are created, a number appears over the Notifications button in the Fast Bar that details the number of unread messages. This number includes notifications that have not been shown as message banners because they are muted in the notification settings. If you are not logged into Avid Content Core when the message is generated, the icon displays the number of notifications that you missed while you were away. The counter clears itself after you access the notification.
You can access missed notifications in the Notifications app. The Notifications app also provides notifications for which no message banner was shown because they have been muted in the notification settings.
To access your notifications in the Notifications app:
Click the Notifications button in the Fast Bar.The Notification app appears as an overlay window from the right side of the user interface.
If more than one notification of the same type is available, these notifications are grouped and shown as a notification stack with the most recent message appearing at the top. A <number> total on the upper right corner of the latest notification shows the current number of notifications within this group. If there are unread notifications in this group, the corresponding number is shown on the upper left corner; this number will disappear once you read all notifications of this group.
The following illustration shows a group of ACC Automation notifications (top), a group of Review and Approval notifications (middle) and a single Tasks app notification (bottom).
When you click on a notification, the group is expanded, and a header and Show less buttons are shown for the expanded group. The <number> total information is not shown for the expanded group. Within each group the notifications appear in order that they were received, with the most recent message appearing at the top.
The right-side of the Notification app may includes a vertical scroll bar that you can use to navigate to older notifications of the expanded group. The application retains up to 100 notifications. If there are more notifications, a Load more button is shown below the bottommost notification group. Clicking the Load more button loads 15 additional notifications for each group (if available).
To use your notifications:
Click on the notification of a collapsed notifications group.
The group is expanded and all notifications are shown for the group.
Click on a notification.
For a Review and Approval task notification, the Review and Approval app opens. The attached asset is loaded into the player.
For a task notification, the Tasks app opens. The corresponding task is selected in the Tasks list and its details are shown in the Details panel.
For an ACC automation notification, the default app for the referenced asset opens if an asset is attached to the notification. If no asset is referenced, clicking the notification does not initiate opening an app.
To load more notifications:
Click the Load more button.
Up to 15 additional notification are loaded for each group (if available).
Expand the notification group and scroll down the list and continue scrolling when you reached the bottom.
While you scroll down, an "infinite" loading is applied and more notifications are loaded.
To close the Notifications app:
Press the Esc button.
Click the X in the upper-right corner of the app.
Click in another area of the user interface (anywhere outside of the Notifications app).
Click on a notification that opens a referenced default application.
