Search App Shortcuts
Keyboard shortcuts available when working in the Search app are listed in the following table. Some keystroke combinations only work when the cursor is located in a certain section of the app; the Focus column in the table specifies the section of the app when that is the case. For more information on the app and its sections, see Using Search and the Search App.
Shortcut |
Description |
Focus |
Tab |
The tab key performs multiple actions within the search header. In general, the following is true:
Search Header |
Left Arrow |
Moves to the previous field of a multi-compound value (like month/day/year) |
Search Term (pill) |
Right Arrow |
Moves to the next field of a multi-compound value (like month/day/year) |
Shift+Tab |
Shift+Down |
Accesses the Search Term short menu |
Up Arrow Down Arrow |
Used to navigate the Search Term menu, Search Type menu, Super Pill menu, or fields in a multi-compound value. |
Shift+Left |
While holding the Shift key, this action highlights the text to the right of the cursor. |
Shift+Right |
While holding the Shift key, this action highlights the text to the left of the cursor. |
Ctrl+Shift+Left Cmd+Shift+Left |
While holding Ctrl+Shift keys, this action highlights the whole text to the right of the cursor. |
Ctrl+Shift+Right Cmd+Shift+Right |
While holding Ctrl+Shift keys, this action highlights the whole text to the left of the cursor. |
Home |
Moves the cursor to the beginning of the search term text field. |
End |
Moves the cursor to the end of the search term text field. |
Enter (Windows) |
Executes a search |
Enter (Windows) or Tab |
Selects value in pill type drop down or match drop down |
Tab |
Adds a new pill with the AND ( & ) operator |
Search Term (operator) |
Ctrl+Backspace (Windows) Cmd+Backspace (macOS) |
Clears all search criteria including Search Terms and Filters |
Search app |
Used to navigate to the previous asset Used to navigate to the next asset Keep arrow held down for rapid navigation. |
Results |
Shift (hold) + Up Arrow Shift (hold) + Down Arrow Shift (hold) + Left Arrow Shift (hold) + Right Arrow |
Used to select multiple consecutive assets |
Results |
Enter (Windows) |
Opens the asset in the Player (if applicable) |
Results |
Esc |
Closes opened drop downs, reverts changes in the pill and converts pill into read mode |
