Configuring the General Settings
The General settings apply to a wide variety of apps and areas of the user interface. You can configure any of the following settings to customize your Avid Content Core experience.
Setting
Description
Appearance
Allows you to configure the user interface's general theme. Options include:
  • Light: Applies a light theme to the user interface
  • Dark: Applies the traditional dark theme
  • System Default: The user interface adopts the color theme that is set on your workstation's operating system.
Appearance settings apply to the ACC user apps, and do not apply to the administrator apps.
When you select a new theme, ACC applies the color changes immediately. However, your settings are only saved after you click the Save button.
Time Zone
The Time Zone setting is used by Avid Content Core to display dates and other formatted data according to your selection.
The default setting is “Use System Timezone,” which uses the time zone that is configured on your workstation's operating system.
Date Format
Defines how dates and times are displayed within the ACC user interface for your individual account. Select the format you want from the drop-down menu.
  • DMY: DD.MM.YYYY HH:mm:ss Z (Alternative)
  • DMY-slash: DD/MM/YYYY HH:mm:ss Z (European)
  • YMD: YYYY-MM-DD HH:mm:ss Z (International)
  • MDY: MM/DD/YYYY hh:mm:ss A Z (U.S.)
hh = 12h format
A = AM or PM
HH = 24h format
Z = Time zone (offset from UTC)
To configure the General settings:
  1. Open the User Settings.
  2. In the User Settings navigation panel on the left, select the General group.
  3. Select an appearance setting from the Appearance menu.
    Appearance changes are applied automatically as you make your selection.
  4. Select a new time zone from the Time Zone menu.
  5. Use the Date Format menu to define how you would like to have date fields appear in the user interface.
  6. Click Save to apply your changes.
    Alternatively, you can click the Revert button to return the settings to their previous state.
